I do not think it would hurt it at all. Are you speaking of adding it to the bottom front of the case, around the HDD bay?
It is my opinion that more fans blowing in (positive pressure) is better then more air blowing out of the case (negative pressure). Though since the fan is on the bottom i would suggest some sort of dust filter, one can be cheaply made with panty-hose, or you can buy one.
