I am looking to add a Radeon 7000 Mac Edition to my PowerMac G5 but I am not sure if it will work correctly.
If I add a 7000, will my primary video card loose any performance? Will it disable some features to match the 2nd one?
I know I am pretty poorly worded, so go ahead and ask for clarifications if needed.
The only real game I play is World Of Warcraft. If I loose any performance, I don't think the game will be very playable.
Info:
Dual 2Ghz G5 Rev A
Few gigs of memory
Not sure the video card, reported as 9600 Pro by system profiler, but I don't think that makes sense. It is the stock card in the Dual 2 Rev A systems.
Right now I have two displays on my video card. A 23" Cinema is on ADC, 17" 170MP on a DVI->VGA adapter. I want to buy another 23" cinema, put it on the primary, then drop the 170MP onto the R7000.
Info:
Dual 2Ghz G5 Rev A
Few gigs of memory
