adding a 2nd m.2 drive - imaging possible from original?
klepp0906
so long story short - i purchased a m.2 drive after having my mobo die. (figured good time to upgrade the rig)
Eventually id like to add another m.2 and stripe them.
If i were to spend the time between now and then setting up windows, id hate to have to dump the pc and begin anew. Is it possible to create an image from the initial windows install on the single m.2 drive, add the second m.2 and create the array, then restore the image to the newly created array?
Thanks guys - couldnt find this info elsewhere with much accuracy.
it is possible to create an image from the initial windows install on the single m.2 drive, add the second m.2 and create the array, then restore the image to the newly created array. However, there is no 100% right way to do this. Everything depends on drives and the system where they will be placed.
Links below could help:
https://forum.acronis.com/forum/acr...esolved-restoring-single-ssd-image-raid-0-ssd
https://social.technet.microsoft.co...new-raid-0-configuration?forum=w7itprogeneral
http://www.hardwarecanucks.com/forum/storage/69363-adding-raid-0-array-system-single-ssd.html
https://www.neowin.net/forum/topic/...sd-to-raid-0-without-reinstalling-windows-10/
https://social.technet.microsoft.co...ge-onto-new-raid-0-array?forum=w7itproinstall
if you activate the raid and run the single m2 off that then windows will have the driver already and you should be able to do what you want to do.
It's be nice to have an image so you could try doing this multiple times, in case of component failure or you decide you want to explore things like install on pcie cards for cooling, etcetcetc.
Do you have an appropriate sized SSD handy for a backup?
