Adding 2 120mm Blowholes
Temperfied
I have an Aerocool Masstige.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811196011
1 Front (Intake) 120mm
3 Side (Intake) 80mm's
1 Rear (Exhaust) 120mm (w/ Zalman 9500 Lined up with it)
My dilemma is, My video card is on top (Being a BTX Case) and the heat it gives off has nowhere to escape.
I want to add 2 blowholes to the top of the case, 120mm. I have someone to cut the holes for me. Not the issue.
I need a Fan Filter.
Would this one be my best bet? I think it might look the best.
http://www.coolerguys.com/120stmefigr.html
Thanks for your opinions,
Temper
There is no need to filter exhausts, they're only needed on the intakes. Filtering the exhaust just decreases its effectiveness.
If all you're after is some protection, wire or steel mesh grilles look cool.
If you have any particular recommendations, it would be appreciated.
Full agreement with what Captain Slow said.
That grill looks a little restrictive. Wire grills are all that I will use. Even those can create a small amount of noise.
