Negative Decibel
- Dec 13, 2005
Looks OK. You need an image with no flash - just the UV. To avoid the typical blue wash effect try
re-setting the white balance on your camera. if so equipped that is.
would be even cooler if you had a mobo & cables that were the type that glows to blacklight'sStill very cool, though!
Well, I was thinking about that, but I really went out of my way to do some cable management. I have one sata, and one ide. Both are black, and I don't like drawing attention to the cables...
Now when I add some water cooling, that will be another story...
