Kurt@BInvisions
- Jul 4, 2004
My Primary SATA Hard Drive with Windows XP installed is showing up as E: Drive, while master IDE Hard Drive is showing up as C:.
The original setup was with two IDE Hard Drives, but I wanted to add this SATA Hard Drive. So I removed the Slave HD on the primary IDE channel, and simply connected the SATA Hard Drive, setting its jumper as Master.
So, I now have:
1x SATA HD set to Master (E
1x Primary IDE 0 HD set to Master (C
2x Secondary IDE DVD Burners, IDE 0 set to Master, IDE 1 set to Slave. (G: and H:, respectively - skipping F for my thumbdrive).
I can't change my SATA Hard Drive to C: through Disk Management because it is telling me that you can't change disk letters on disks that are the system volume or boot volume.
SATA is set as the primary channel in my BIOS, and IDE is set as secondary.
It boots up to my SATA installation, which is good, but I want it to be drive C:.
PLEASE tell me what I can do.
So, I now have:
