I had a 2Wire router/model for my DSL running wireless and my local LAN. I added a Netgear Wireless N router and have one ethernet cable going from the 2Wire to the Netgear for uplink.
All PCs (hardwire) and wireless are using the NetGear. Wirless is disabled on the 2Wire.
The Netgear is picking up 192.168.1.80 as the "internet" address and the 2wire confirms this is the only IP address assigned.
All is well so far...
I also see my desktop (billkim-pc) on the Netgear as 172.16.0.2, however I can't telnet to it, remote desktop to it or anything.
When I run ipconfig on the desktop it tells me "billkim-pc"'s IP is 172.16.0.2
C:\Users\BillKim>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection 3:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::990c:55a:4a79:b365%18
IPv4 Address. . . . . . . . . . . : 172.16.0.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 172.16.0.1
However when I run nslookup I get this. The same thing happens from my Mac client. Note that it thinks the IP is a 192.168.x.x which is the subnet of the 2Wire machien it used to be on. It no longer is....
C:\Users\BillKim>nslookup billkim-pc
Server: UnKnown
Address: 172.16.0.1
Addresses: 192.168.1.77
192.168.1.77
I ran ipconfig /dnsflush on the desktop and the same on my remote clients. I can't connect via IP address from the remote machines either...
Any ideas?
Thanks
Server: UnKnown
Address: 172.16.0.1
192.168.1.77
Any ideas?
Thanks
