Added 1GB memory, now games dont work.
Becks4Me
OK So its value select corsair ddr 400 512 sticks, i ordered the same exact 1 gb in 2x 512 sticks as the 1st ddr400 512 corsair value i had so its all the same ram model #.
i added the gig had some issues at first changed some stuff around then it worked but now when i play cs:source for example i will connect to the server and the game will freeze right after i choose teams,
also on the boot screen when it shows ide devices it says check pc health. im running 49 degrees celsius and i remember when i used to cool the pcs more i could get them down to like 38-44c so might my computer be freezing because the cpu is to hot?
seems like the bios is set up right i have default cpu ddr frequencies and all - also the pc doesnt seem as fast and when i just tried taking out the 2 sticks running the original 1.... this seems bogus.
thanks for your time and any help
Without any more info on this it sounds like you *might* have a faulty stick of ram. The simplest thing to do is take CS:Source or some other type of program like sisoft sandra or 3dmark that puts stress on the system you have issues with and test the configuration as follows.
Take 1 of the new sticks, plug it in, boot up, and see if you are having issues in your program of choice. In this case CS: Source. If you try each of the new sticks individually and you have no problems then you pair one of the new with the old and try that.
Chances are it's just a bad stick.
However,
It's been a while since I've had any issues with ram upgrades, so my knowledge of the subject is a little outdated. Lets go through the checklist...
You didn't post any motherboard specifics, so my next question is:
Could you be having a Dual Channel issue? Is the motherboard dual channel capable? Does it have a setting you can force on or off, or should it auto configure all on it's own. Some ram is not certified for dual channel set-ups and you will experience errors when trying to run in dual channel mode if the ram does not support it
Also, depending in the motherboard and how new/old it is, there might be a requirement where you have to use ECC certfied RAM when you fill up all the slots. This last item doesn't sound very likely as my last experience with that issue was a 4 ram slot Abit board for Athlon thunderbirds
The other thing to check is if the default is set too high or too low on the CAS. Some ram is cas 2.5 and won't run any lower, usually this is not the case, but if you have three 2.5 sticks running at CAS 2, and one won't really run at the lower latency setting, you'll get wonkyness.
However, you might want to consult the vendor FAQ page or your manual to see if any restrictions apply, or if there are any known compatibility issues with the ram you are using in that particular configuration with that board.
Let us know if you get it figured out!
Thanks for all the informationI played around I think it was the ram settings I manually set them to be instead of on automatic so it is working smoothly now and cs runs normal.
Not sure about the cas settings going to look at that tomorrow see whats the rams rated at and what its set at - also tomorrow i am setting up a maze 4 dangerden waterblock and random system parts so maybe i could post pics.
Its a Sempron 2400 by the way and on a gigayte basic value board with a good 160 stickin to my seagate sata and then a 5500 i think fx msi pretty good after i watercool tomorrow going to oc some, not sure if i could go far with the videocard with the stock cooling will have to get a waterblock for that also
Since you're classified as a noobie on this board, i'm going to pretend for a minute that you are precisely that.
http://www.cpuid.com/cpuz.php
CPU-Z is a great program for pulling information from the motherboard, processor, ram, etc... This information is pulled directly from the chips, and will tell you more information than any sticker or book will, including memory timings.
http://www.memtest.org/
Memtest86+ is a program that tests your memory using a variety of tests to ensure that no bit is left unchecked. After burning the image to a CD, simply boot from it, and use the on-screen menu to check what can't be done inside of windows.
Add these 2 utilities to your collection. They are a troubleshooters best friend, and best of all... free
As a side note, just from your posts on this thread, its easy to see that you really don't know much about what you're doing when it comes to diagnosing, troubleshooting, and fixing a problem. Simply "playing around" until you find something that works is how amatuers fry their equipment. I recommend extreme caution if you choose to continue with your watercooling and overclocking ideas. Keep in mind that you may cause permanant damage that nobody will be able to help you with. Also, void your warranty, and your wallet suffers the damage.
i overexpressed my definition of fiddling - fiddling infact means troubleshooting and properly figuring out - just like the word fiddle haha
im pretty experienced with ocing and cooling done it for several years and know about the cpu z program thanks for the memtest ill see about that.
Good deal!
Glad to hear you got it figured out, and that it was relatively simple to fix..
