Add tv out
Sephiroth
Hello,
Is there a way to add a tv-out capability to a laptop if it is
not integrated(like some USB/PCMCIA card)?
Hm, is my question stupid or does nobody know? I looked into TV cards but they only add TV-in so i m at a loss here
This is kinda what you are looking for I think. But I would try Froogle or something of the sort
http://www.baber.com/laptops/margi_display_to_go.htm
That looks nifty, but with that you have to stack a vga->tv converter.
well, the 9600 supports tv out natively , maybe I could use come kind of cable/converter?
If your laptop doesn't come with a TV out connection the only way to add it would be to use a scan coverter. (box that turns the VGA signal into a TV signal)
