Here at work, we have a folder share which contains user data. The parent "Users" share is visible to everyone and anyone can list the contents of the folder. However, each subfolder has specific permissions so that only the user in question can view the contents of all folders within. I need to add a security group to all of these folders with full access rights, without changing the individualized security settings of each subfolder to that of the parent folder.
At first I was messing around with a powershell scripts. However, all the scripts I can find rely on inheritance of the sub folders to be enabled, which is neither possible nor desirable.
Has anyone found a solution to this problem? I know I'm not the only one but I'm not having much luck finding a solution on Google.
