Add More Memory or Not!
cheyneboy
My current system consists of MSI Neo2 Plat w 3500 Winnie and two 512mb sticks of OCZ EL DDR PC-3200 Platinum / Revision 2. I also have two sticks of the Corsair TWINX512-3200LLPT that I'm not using. MY Question - -, should I install the Corsair in my system along with the OCZ mem or do you think nothing would be gained by doing so. ---- Thanks in advance for all suggestions.
Never like runnin different types of ram, but....
try it
If you have alot of stuff open all the time or do alot of Photochop or cad stuff or rendering or math calculations then go for more other wise get ye fraggin!
if you have it, use it.. i don't see how it could hurt.. maybe.. create more heat, or draw more power away from your power supply which would cause you to be able to overclock a bit less.. or if they had different timings.. but they both sound like they are pretty comparable, are they?
