sonnybobiche
- Jan 1, 2006
Dishwashing detergent effectively reduces the surface tension of water. I figure adding a few drops to my current loop would improve flow rates dramatically. Anyone have a contrary opinion?
Well, yeah, that toomasher said:Flow rates are determined by density and viscosity, not surface tension.
Dave332 said:add propolyne glycol, also known as common antifreeze.
Eh? Either works fine...ethylene glycol cools a fractional percentage better...but its highly toxic.malicious said:
do NOT use propolyne glycol
DO use Ethylene Glycol ...
10-15% Ethylene Glycol and Distilled (not de-ionized) water will do
You need to account for anything that the water touches. Copper and Brass have a pretty low galvanic delta (since brass is mostly copper), but chrome, aluminum, and steel are all very high against copper.Justintoxicated said:What about copper and brass, with aluminum fillport that is not in direct contact with water? What abotu the chrome barbs that stick out of everything? Do I need to account for those too?
masher said:Eh? Either works fine...ethylene glycol cools a fractional percentage better...but its highly toxic.
And the concentration you should put in your loop isn't fixed, it depends on the galvanic potential of your system. If you have dissimilar metals, then a 15% solution would be about a minimum I'd recommend. If you have an all-copper system, you can get by with a 5-10% solution.
I did. I think you missed this part.malicious said:hit the link
Pure propylene glycol isn't used for any antifreeze mixes, there are always additional additives, inhibitors, and stabilizers. Not even ethylene glycol gives good performance for all metals.An uninhibited 30% reagent grade propylene glycol solution [caused] unacceptably high pitting corrosion of aluminum...The inhibitors in the inhibited propylene glycol antifreeze-coolant were as effective as those in the inhibited ethylene glycol in preventing pitting of aluminum
malicious said:
I don't use Hydrx for Water Wetter either.
sonnybobiche said:Dishwashing detergent effectively reduces the surface tension of water. I figure adding a few drops to my current loop would improve flow rates dramatically. Anyone have a contrary opinion?
Um, that's not how galvanic corrosion works-- the anodic metal experiences accelerated corrosion, while the cathodic metal experiences less than normal.Chernobyl1 said:my system consists of an aluminium radiator and a copper water block...I checked the block for galvanic erosion...The block looks as shiny as it did when new and there is no evidence of corrosion
Not with aluminum in the loop, no. You'd need to use zinc or something with a higher anodic index.JustKidding said:I have to jump in and ask... Why not use a 'sacrificial anode' to protect the whole system? Would not a replaceable piece of bronze somewhere in the loop due the trick?
Dark_fire said:it might work, as most if not all hot water heaters have a similar "sacrafical anode rod" in them to protect the tank.(yes i can wire and plumb houses, as well as build computers at the age of...........15. dont believe me, i wired our basement and it hasnt gone up in smoke yet)
Well, you have to remember the electrochemistry of corrosion inhibitors functions very similar to what a sacrificial anode does, and so in either case you're going to want to regularly flush to remove scale and sludge. Its not going to be a huge difference either way.zer0signal667 said:Guys, think about what happens to sacrificial anodes as they perform their function. Do you want remnants of that floating around in your loop?
But pure water doesn't stay pure and non-conductive for very long. Water in a loop is going to become mildly conductive, just from a few free ions it picks up from the materials its in contact with. If you have dissimilar metals, then you need to worry about galvanic corrosion.Actually, if your water is non-conductive then no worries (water is only conductive when mineral elements are introduced).
In all three cases, you ideally want corrosion inhibitors. In the second case, you can skip them for brief periods, and in the third, for lengthy periods...but there's really no reason not to use them.WHAT do I want to put in my water when I water cool under the following circumstances?
1: copper block, aluminum rad?
2: all copper?
3: all aluminum?
Not really, I just use auto antifreeze myself, nothing fancy. I don't have any experience with the PC-specific inhibitors.jmahler said:Thank you for your informative post, Masher. Any brand reccomendations? I am about to rebuild my system anyway.![]()
Not a propylene-based antifreeze, no. For those, you want an abiotic agent.Last time i check antifreeze is suffcient at killing most anything living in solution
