adapter question = which display port adapter?
matrix563
http://www.monoprice.com/products/p...=1042803&p_id=5714&seq=1&format=2#description
that is mini DP male to DP female.
should i get that and plug what i currently have into it:
http://www.dealextreme.com/details.dx/sku.20776
or, should i just buy this:
http://www.monoprice.com/products/p...=10428&cs_id=1042802&p_id=5107&seq=1&format=2
i don't need to be told it doesn't work with eyefinity cause i know it does ;). just wondering which route i should guy, the mini DP to vga adapter, or the mini DP male to DP female adapter and plug my current DP to vga adapter into it?
or should i just buy this:
http://www.superbiiz.com/detail.php...c6a8a14af420b226e81b64fb47cd954eaf4a25ca335bf
going to be using the 6950 flashed to 6970. need to update sig ;)
i already haev a dp to vga adapter that works. your dvi to dp is the 005b, the one i linked is 006b. is the 6B better?
no i meant not using 3 x30's :). i may consider that $30 adapter. i might try the $4 monoprice one as i'm thinking it will work and i'm trying to keep costs down
You should buy the mini-DP -> DP adapter and use your current DP->VGA adapter on it. mini-DP->DP is just rearranging the wires, no compatible issue will change and you already have the more expensive part, the DP->VGA active adapter.
You will also likely still have use for the mini-DP->DP adapter after a few changes in hardware a few years down the line.
yeah thats what i'm going to do barring any compatibility problems once i get it. the dp to vga was only $16 something so not all that expensive. dealextreme ftw :D. i just wish monoprice would get it back in stock sooner.
