Adaptec Storage Manager
nry
Hi
I have successfully setup my file server running ESXi 5 as the master OS, passing the controller through using DirectPath I/O to a ubuntu 10.04.4 x64 VM
Code:
root@nas:/usr/StorMan# /usr/StorMan/arcconf getconfig 1
Controllers found: 1
Controller information
   Controller Status                        : Optimal
   Channel description                      : SAS/SATA
   Controller Model                         : Adaptec 5805
   Controller Serial Number                 : 8B26106A941
   Temperature                              : 68 C/ 154 F (Normal)
   Installed memory                         : 512 MB
   Copyback                                 : Disabled
   Background consistency check             : Enabled
   Automatic Failover                       : Enabled
   Global task priority                     : Medium
   Performance Mode                         : Default/Dynamic
   Stayawake period                         : Disabled
   Spinup limit internal drives             : 3
   Spinup limit external drives             : 0
   Defunct disk drive count                 : 0
   Logical devices/Failed/Degraded          : 0/0/0
   SSDs assigned to MaxCache pool           : 0
   Maximum SSDs allowed in MaxCache pool    : 8
   NCQ status                               : Enabled
   Statistics data collection mode          : Enabled
   Controller Version Information
   BIOS                                     : 5.2-0 (17544)
   Firmware                                 : 5.2-0 (17544)
   Driver                                   : 1.1-5 (2461)
   Boot Flash                               : 5.2-0 (17544)
As I use a MacBook and the GUI only works on windows I have a VM running on the Mac inside VMFusion (Windows 7 Pro) with Adaptec Storage manager installed.
I can connect to the host no problem at all, it detects all 8 drives connected too
The only option I seem to have enabled is the ability to create a hot spare out of one of the disks.
As you can see by the attached image, I cant create anything, change any settings etc.
All I can think is that I logged in using my username and not root, but I can't login as root!
Am I missing something?!
Just noticed the HDS5C3030ALA630 drives are showing up as 2TB not 3TB too!
I would have thought that I would be able to configure the controller at least though?
Enabled them, root user was disabled, so enabled that and gained access.
