Adaptec 4805SAS help needed
naro
hi guys, i need some help with my Adaptec 4805SAS controller card.
I've already got Windows XP installed and i added the Adaptec 4805SAS card to the system. I installed the drivers in windows.
Afterwhich, i initialised an HP OEM Seagate Savvio drive and created an array and formatted it.
Then, i reboot and after the verifying DMI pool data screen, it just hangs there with a black screen.
can anyone help!!! thanks
okay, i've flashed the Adaptec card to the lastest firmware. I've also updated my motherboard (AOpen i915Ga-HFS) to the last firmware. But it keeps failing to boot into windows. It keeps hanging with a black screen just before the Windows XP screen with the scrolling bars.
I tried something rather dangerous by booting into windows without the SAS hdd and plug it in when i'm in Windows. This only works when I have created an array in the Adaptec BIOS and then remove the hdd before booting up. In the Adaptec Storage Manager, it'll be detected as a logical drive.
If i do not create an array in the Adaptec BIOS, the SAS drive will only appear as a hotspare in Adaptec Storage Manager
Is the boot order set properly in BIOS? You should have the disk with Windows set to boot before any external cards or the SAS disk if it appears there.
yup.. i have the boot order setup properly. Even if the boot order is not in sequence, it will seek out the next hdd with a boot loader..
it seems like the driver that i've installed in Windows is not working and its causing the Windows not to load.
