paradoxblue
- Jan 4, 2006
I have had this card sitting here for a while. and I havn't set enything up on it because the Site tells me. max drive size is 1tb and max array is 2tb...
Is anyone aware of firmware update etc I can use to make this bigger?
Otherwise it's somewhat of a waste. I would just buy a 2tb drive and be done with it.
Where I'd like to hit the 10-12TB eventually
Thanks
Shawn
EDIT:
I should add
If I need a new raid. i'm looking for something 6-8 ports that I can add port multipliers to and have a very large raid setup.
Thanks
Shawn
EDIT:
I should add
