AD CLeanup
civimike
Howdy all....
I was wondering if anyone could suggest a Good clean up application for Active Directory. My Domain has tons of machines and user accounts, but i know at least half of them are old and unused. im looking for a tool that will give me a date of last use....or even better something that will give me a listing of accounts that havent been used in 90 days/120 days...
Prefrable a free app, but i will pay if the product is good, does what i need and isent a giant resource hog.
Thanks
THanks for the Sugestion, Ive tried that software before, its either really slow or hanging on something. It just sits at the scanning screen. any other software anyone may suggest?
Couldn't You do a custom LDAP query, to find the objects?
(no automated removal, but at least you got a list)
If it's hanging, that may be an idication of a bigger problem. I use the Active Directory Health Check Tool from MS, but I got that from a MS engineer and you can't just download it. I would try to figure out what it's hanging on first.
Thats would be great, unfortunitly i am not that great at writing LDAP querys, any good refrences i could look at?
I looked at this to get myself started: http://www.petri.co.il/ldap_search_samples_for_windows_2003_and_exchange.htm
(I was setting up query based distro's in exch2k3)
You might need this reference http://msdn.microsoft.com/library/d...adschema/adschema/active_directory_schema.asp for all of the classes, attributes, etc in the schema.
edit: you may be interested in the Last-Logon property of either a User or Computer.
Thanks for the help, ill look into this right now
If you are doing last login you need to check against every domain controller unless you are running Windows 2003 Native AD. Its not a domain property otherwise and each DC will store an individual lastlogin/lastlogoff for every user to have logged in using it.
Just tell me the criteria you want to find people/workstations/groups on and I'll write you out the query.
