Active Northbridge Cooling?
StarWolf
Is active cooling on the Northbridge really important or is a heatsink enough? Mine with h/s and 600MHz o/c gets "pretty warm" but it's not too hot too touch. I have a 92mm side case fan which has pretty good airflow over the mb and northbridge area. How much can a hot northbridge limit a overclock and should I get a fan?
If your at a limit with your o'c'ing adventures and the cpu temp is fine aswell as ram then the northbridge might be the problem. But if not, ' pretty warm' is hardly anything to worry about, though it can't not help to put a fan on it heh. On the p4's it was more of a neccesity but with your airflow from the side panel it should be ok. You could take it off and put AS5 then put it back on to help it a bit though :)
a case fan blowing on the area should be enough.
just out of curiosity, can you get chipset temps with everest or smartfan on that via board?
Everest shows CPU, Aux and GPU but I never trust Everest. Most of the time it shows my CPU in the 90's C. Bios reports it in the low to mid 30's. Sandra shows, board, CPU, power and HD. Haven't tried Smartfan.
