Hi,
I am selling my Logitech 2300 set and looking to upgrade to something a bit nicer. So far, I have my mind set on the Swan D-1080MKII or M-Audio AV40. Which one is superior?
Moreover, I have been looking into the alternative of buying a receiver and passive speakers as the monitors are not really upgradeable.
Which route do you all think is better to take? I will be using the speakers mainly for music and movies, for mid-field listening...therefore the sound needs to fill a smallish sized room (around 12X12).
Looking at these for Receiver + Passive:
http://www.thespeakercompany.com/TSB-525-2-Way-Bookshelf-Speaker-Pair-P45C6.aspx
http://www.thespeakercompany.com/LCR3-P-Series-Home-Theater-Front-Speakers-P41C6.aspx
http://www.amazon.com/Onkyo-TX-8255B-TX-8255-Stereo-Receiver/dp/B001AMSPQI/
http://www.amazon.com/Sony-STR-DH100-2-Channel-Audio-Receiver/dp/B001TP3CH8/
http://www.amazon.com/Yamaha-RX-V363BL-5-1-Channel-Theater-Receiver/dp/B0013ZGOYM
I will eventually pair a subwoofer with either combination. My pricerange is around $300.
