Aug 13, 2004 #1 O oqvist [H]F Junkie Joined Dec 24, 2001 Messages 8,936 I know there is one developed by some called MA*Labs or something but I can´t find them? I don´t know if Tomshardware left out some letter for the * for some odd reason?
Aug 13, 2004 #2 2 2Fresh 2[H]4U Joined Aug 10, 2003 Messages 3,767 I only know of the Thermaltake ones
Aug 13, 2004 #3 O oqvist [H]F Junkie Joined Dec 24, 2001 Messages 8,936 Those don´t do anything good There is one with two tiny 40 mm fans but with my case there seem to be hard to do any better for RAM cooling.
Aug 13, 2004 #4 K Koslov [H]ard|Gawd Joined Aug 31, 2003 Messages 1,889 should consider making your own waterblock for your memory module or ask someone to make you some
Aug 13, 2004 #5 O oqvist [H]F Junkie Joined Dec 24, 2001 Messages 8,936 1. I don´t have watercooling. 2. I have two ram modules 3. I am a bit hesitant to phase change cool my ram modules . Anyway I don´t want to void my warranty otherwise I would just remove the heatsinks since they run cooler without
