When one creates a new attribute for a class in the active directory schema how do you set it active in the template for the creation of an object?
Example...Say I added a attribute called EmpType under the User class. This thing would say whether the dude was a temp, a supervisor, a lackey, a corporate guy or whatever. I make the new attribute and integrate it into the user class. However I wait the 5 minutes for the Schema to replicate and I got to create a new user and it doesn't show up anywhere. I can't figure it out it's not under the Schema add-in
Help???
Help???
