Acrylic Tubing.
Elleric
I was wondering if anyone knew of a web site that sells acrylic tubing in smaller quantities. TAPS and US sell only in 5-6 foot lengths.
Im looking for
2 - 6 inch OD, 1/8 inch wall thickness, 12 inch length (if i can get a bigger OD, 12 inch OD is better but no smaller then 6)
2 - 3 inch OD, 1/8 inch wall thickness, 4 inch lenth
2 - 3 inch OD, 1/8 inch wall thickness, 6 inch lenth
So buying 5+ feet of tube wouldnt be good because id only use less then half of each sample. any ideas?
Ebay was the first thing that came to mind for this. http://stores.ebay.com/eStreetPlastics has some tubes for sale and there are others as well.
McMaster sells acrylic tube in 12" lengths but a 6" OD x 0.125" wall is 20USD. McMaster has up to 8" OD but a 12" length will set you back 40USD.
Edit: McMaster has a 14"OD x 0.500" wall x 24" length... only set you back 765USD:eek:
mcmaster would be my last resport. they are very expensive, but lest cost then buying 6 feet.
the Ebay store looks promising, checking it out now.
