Hi everyone,
I have just barely begun my work on my new pc, but an order to mcmaster would be wasted if you didn't save on shipping by getting everything you need. I will be finishing off my mod by giving the side panel of my stacker a custom window. This however is not your average window, I am completely insane and have decided to attempt to replicate a triangulated curtain wall design I came up with in my middle college days:
I would say each triangle's side would be between 3 and 5 inches long. As with the models, I will cut them as I go, fitting along previous pieces and creating the form freely. The side panel of the case would be cut in a jagged pattern, framing the points of contact for the triangles. I think I will want to find a balance between weight and strength with my selection of acrylic. Now finally, the questions:
1. What kind of acrylic would be best for this application, extruded or cast?
2. What thickness would be best?
3. What should I use for adhesive between the triangles? (The triangles will likely never meet flush, so I figure something with some thickness to it will be needed to fill in the joints)
4. What should I use for adhesive between the triangles and the metal case?
Thanks in advance to anyone who can help me out here. It's going to be a lot different working with this than it was when I was using hot glue to join triangles that were on average 3/4" to 1/4" per side.
