Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Best advice I can give you is to forget ordering online.
Pop down to your local industrial estate and hunt down plastics suppliers there - most will have off cut bins with anything up to 2 foot sheets of 'scrap' of various colours... find the foreman and haggle with him.
Of course, you can also buy full sheets from them.
cheers guys well i took your advice and after a trip down the local insustrial estate found a sign manufacturer who was happy to cut to size the piece i needed for only £6
