Acrylic,Lexan,Plexi, Heater ??
Koslov
I'm trying to find an affordable plexiglass heater to bend the plexiglass,lexan,Acrylic.
I have also a few other questions:
#1- Does anyone know the best "glue" to bond lexan or plexi together? i've hear about weld-on #16
#2- What is the recommended thickness to make computer case?
Is it better lexan or plexi is fine?
#3- What kind of cutting tools do you recommend for lexan,plexi?
For heating, I've always used a heatgun sitting upside down on a table. I heard a jigsaw works to cut it, then file it down, then sand. I dont know what kind of glue to use, but my old shop teacher used to use some stuff that would like... 'melt' the plexi together.
TAP Plastics also had a strip style heating element for sale... more expensive than a simple heat gun, but it can heat the whole area for a fairly large bend pretty easy and very evenly.
will try to find a link, but it's another option...
-Hex..
thanks guys
This plastic strip heater is a very light duty strip heater. The strip must be on the acrylic sheet for up to 20 minutes to bend 1/8" material, even longer for thicker material. Safety note: Never leave the strip heater unattended when in use.
20minutes for a 1/8 is pretty long ehhe
I might buy the more powerfull unit at 155 - 195$ with a few friends.
this is a simple item.... just probably hard to find. I really think that it could be had for a reasonable price (maybe just above the $45 bucks, but for something more powerful).
good luck!! let me know if find anything!
-Hex..
Originally posted by linear
Also, phasmatis nox will be by shortly to tell you you should only consider Lexan.
Anyone found to be using plexi where lexan could be used must be shot, burned, and fed to wolves. All at once.
I use this for many things, but I have never tried it on Lexan....maybe I will since I am drawing out some custom designs that I am wanting to use in an upcoming 'from scratch' pc that I am wanting to make.
Bosch
I also use this one when I need a more control of the heat.
LED Heat Bosch
