Acrylic clear cases
mokkapoop
Does anyone here own an acrylic case? If so, is the vent flow thru it good? I am thinking of switching from a Lian Li pc-60 case to an acrylic clear case.
Can anyone link me to cases such as these?
I have one. It gets great airflow... I think it looks great but I feel it is harder to make look clean since everything is exposed. sort of like a puter that has been pantsed. anyways... I just got the cheap one off newegg that you assemble yourself. Arrived just fine and took about an hour to put together. I was VERY careful not to scratch anything.
Most are horrible at heat dissipation as compared to aluminum cases. Worse, if you scuff the side of your shoe, it's not hard to fix it on a metal case. On acrylic, your pretty case has just been violated. :eek:
