Maxtr0sity
- Dec 24, 2005
I'm planning to build an acrylic case and mounting a mini-ITX motherboard inside to use as my media center & seed box. I've scoped out the parts that I need and everything, although expensive, will fit nicely between two 12x12" acrylic sheets.
1. I'm using 1/4in thick sheets, will that be sufficient enough for a small case?
2. What should I do about ESD? The power supply case is grounded, so I'm planning to mesh the motherboard screws to connect with the casing.
3. Heat, I'm only using an AMD 45W CPU, the max power draw I'm expecting is around 70W from the motherboard alone, then maybe 20W per hard drive. Should the hard drive have direct contact with the acrylic? I'm expecting the HD temps to be around 40C.
Probably more questions later, but if someone can give hints to these, it'd be greatly appreciated.
