Acrylian 343b
skullen
Time for a new build,case will be the Lian - Li 343b.
Inside will be white acrylic
Top cut and grilled
Rear panel cut and grilled
Rear panel taped cut and also grilled
Test fit and fitted
Where i am at the mo
How i hope the front will look when ive done
Thanks for looking :)
Done a bit more on the case,front panel bolted on these will be changed for black ones
Still gotta do cutouts for grills
Top also bolted on bolts will be changed for black ones also
Side panel on for test dont look to bad,gotta get the window cut out and filled with clear acrylic
Something like this so the window will be flush with the panel,but without the other bits beside it
Thats where i am at the mo
