I have been running this on XP Pro 32bit without issue and the same setup. Acronis is to do the backup on shutdown. It just hangs. I'm given two options. Force the open apps close or cancel. Both options do the same thing. Close whatever is trying to run then shutdown.
Any ideas on how to deal with this? I prefer the backup at shutdown option. There must be a simple way to deal with this.
