I tried googling this, but trying to open the instructions of 1040EZ forms and trying to scroll a page it will be slow as heck then put my monitor to sleep which I then have to reboot.
I'm using Windows 7 Beta and a GTX 260, I did try to disable 3D on Acrobat reader 9 but still kicked out the monitor into sleep. What is weird is viewing and entering info into the actual 1040EZ form doesn't do this, only the instruction pdf. (2 separate PDF files)
Any Ideas? TIA!!
If anyone could try the instructions pdf in vista that has a GTX260, that would be helpful.
Any Ideas? TIA!!
