AcousticPak vs. Nexus Damptek
nsx241
I was looking at getting some sound-dampening foam from AcousticPC, and can't decide between the two options.
Looking for some opinion/advice.
Used Acoustipack in two cases and love it. Will use it on any other cases I buy. A case fully outfitted is quite a bite heavier. Zero experience with Damptek. But Acoustipack is about 50% thicker. My advice is whichever you choose, don't skip, buy more than you think you will need.
