Acer B326HUL (32" 1440p)
Discussion in 'Displays' started by [X]eltic, May 20, 2014.
  1. [X]eltic
    [X]eltic Limp Gawd
    289
    Nov 24, 2007
    After the BenQ BL3200PT, there's now a new 32" 1440p screen on the market, the Acer B326HUL.
    -Acer website:
    http://us.acer.com/ac/en/US/content/professional-model/UM.JB6AA.001
    -Amazon page:
    http://www.amazon.com/Acer-B326HUL-ymiidphz-32-inch-Widescreen/dp/B00JB6HE62
    It's very similar to the BenQ BL3200PT with some minor differences:
    Code:
     ========================== [ Acer B326HUL ] = [ BenQ BL3200PT ] ===
     Screen Size -------------- : 32"              | 32"               |
     Aspect Ratio ------------- : 16:9             | 16:9              |
     Maximum Resolution ------- : 2560x1440        | 2560x1440         |
     Response Time (GtG) ------ : 6 ms             | 4 ms              |
     Vertical Viewing Angle --- : 178°             | 178°              |
     Horizontal Viewing Angle - : 178°             | 178°              |
     Standard Refresh Rate ---- : 60 Hz            | 60 Hz             |
     Colors Supported --------- : 1.07 billion     | 1.07 billion      |
     Brightness --------------- : 300 cd/m²        | 300 cd/m²         |
     Native Contrast Ratio ---- : 3000:1           | 3000:1            |
     Dynamic Contrast Ratio --- : 100,000,000:1    | 20,000,000:1      |
     Panel Type --------------- : AMVA             | AMVA              |
     Back Light --------------- : LED              | LED               |
     Color Gamut -------------- : 100% sRGB        | 100% sRGB         |
     Panel Coating ------------ : Anti-glare       | Anti-glare        |
     D-Sub -------------------- : No               | Yes               |
     DVI-D -------------------- : Yes              | Yes               |
     HDMI --------------------- : Yes (2x)         | Yes               |
     DisplayPort -------------- : Yes              | Yes               |
     USB 2.0 ------------------ : No               | Yes (2x)          |
     USB 3.0 ------------------ : Yes (4x)         | Yes (2x)          |
     SD Card Reader ----------- : No               | Yes               |
     Audio Line In ------------ : Yes              | Yes               |
     Headphone Jack ----------- : No               | Yes               |
     Speakers ----------------- : 2 x 2 watt       | 2 x 5 watt        |
     Power Supply ------------- : Built-in         | Built-in          |
     Weight ------------------- : ~12 kg           | ~13 kg            |
     Bezel Width -------------- : ~13 mm           | ~14 mm            |
     VESA Compatible ---------- : Yes (100 mm)     | Yes (100 mm)      |
     Warranty ----------------- : 3 years limited  | 3 years limited   |
    I found a (Hungarian) review of it too. Use Google to translate:
    http://prohardver.hu/teszt/acer_b326hul_wqhd_monitor_teszt/bevezeto_es_kulso.html
    Looks like the BenQ BL3200PT is the better deal.
    http://www.tftcentral.co.uk/reviews/benq_bl3200pt.htm
  2. kache
    kache Gawd
    725
    Mar 21, 2010
    It appears to be even more laggy than the BenQ, which is already too laggy for gaming purposes. :(
  3. silverwolf0
    silverwolf0 Gawd
    613
    Jan 14, 2004
    The acer site says the power is below 45w. The benq site says around 90watt. How does that work? Brighter upper limit for benq leds?
  4. Church
    Church Limp Gawd
    371
    Mar 12, 2014
    Or someone reporting power usage at average brightness, another one - at maximum. Anyway, one should rather trust numbers from actual reviews, not ones that some manufacturers may game with. I highly doubt for difference to be more then 10-20% for displays made of same panel.
  5. Bluesun311
    Bluesun311 2[H]4U
    2,527
    Sep 21, 2013
    Looked to me like Benq was already pushing the envelope and giving more acceleration to their AMA Premium mode than usual. Slight bit of overshoot, but not enough to complain about. The Acer will vary in that way, and probably it is slower.
  6. phinix
    phinix Gawd
    819
    Dec 13, 2005
  7. 11k
    11k n00b
    20
    Nov 13, 2014
    So i tested yesterday the Acer B326HULymiidphz, thought maybe there is a new charge, but it has the same problem like the Benq BL3200PT. Extrem Flicker and Flash problem, because you cannot disable the overdrive. On the Benq 32" you have some options to reduce it. I made also videos.
    Acer B326HULymiidphz Flicker Flash Problem
    Link 1: https://www.youtube.com/watch?v=btVu8nb1fIA
    Link 2: http://youtu.be/DkjyVfWfvdk
  8. doug_7506
    doug_7506 2[H]4U
    3,209
    Oct 17, 2004
    Came across this after I purchased the ACER. Will have my hands on it Monday. ACER currently is selling refurbished version for $399. http://www.amazon.com/gp/aw/ol/B00JB6HE62/ref=mw_dp_olp?ie=UTF8&condition=all
    Really torn here. This monitors seems to be the perfect size. It offers great screen real estate while offering the same pixel density as a 24" 1080p monitor. Ideally I would buy a 34" 3440x1440 curved monitor, but I can't bring my self to sink 1k into a monitor right now.
    Is that flicker problem something that everyone notices? I will be using this as my monitor at home. So shouldn't really ever use it for more Than 3-4hrs at a time.
    I went with this over the 32" hp envy that is only $80 more brand new. Is the HP any better?
  9. doug_7506
    doug_7506 2[H]4U
    3,209
    Oct 17, 2004
    Just got this in and I'm really disappointed.
    The color shifts dramatically just looking at it. I'm typing on it as we speak and the color fads from gray to dark gray back to gray on [H].
    Going back...
