acer aspire e360 help
tjsooley
Hello the system in question is not stock anymore and i have oc'd a little but b/c acer changes the foxconn bios to the aspire bios can i flash back to the foxconn bios and is this 6150K8MA-8EKRS the right mobo i am like 70% help.
idk i figured it was worth a shot
sorry i will ask someplace where the people know more
nforce 430 acer lockes the bios from manual freq change
amd x2 3800
nvidia 7300 gs pcie
3gb of ddr 400
the best i was able to do with ntune is 2.12 on the x2 and 650 on the video card
Yeah you can flash it back. But I dont know if it's the right bios because you didn't give any information about your motherboard.
That's what it says on the mobo itself? Are you sure it's not the 6100K8MA-RS? If it says's it on the mobo and it is that one in the link then you just need to download an older bios and flash it.
Then there you go. Select one of the bios's from that site and reflash.
