Acer AL2017 for Gaming/Graphics?
Dario D.
Hi all. Quick question, I think:
I'm thinking of getting two Acer AL2017's [link to Newegg], but am an LCD noob, so I'm uncertain if this would be a good choice for gaming AND graphics in one bite. Any suggestions? I'm an independant game developer, and my plate is full of both gaming and graphics, so I need something at least half decent at each, but without spending an arm and a leg. (I already have to get 2 of them for dual-monitor support, and my wallet doesn't like it)
Thanks.
The Acer AL2051w is a better monitor it has a MVA panel instead of the TN in the AL2017; The AL2051w can be found for ~$200
Thanks a lot. Btw, how do you tell whether a monitor is TN or MVA, etc? I read the LCD guide on here, but couldn't find any of those acronyms on the product listings at Newegg.
(btw, they dont seem to carry the AL2051w :(. Dang.)
TN's are usually specced as 2ms or 5ms. Other panel types usually start at around 8ms.
TN's are the only panels types that are 16.2 million colors. Other panel types are 16.7 million. A lot of newer TN's are advertised as 16.7 million, so just know that 16.7m does not mean it is not a TN, but 16.2m means that it is a TN.
I've never seen a TN with a viewing angle spec of greater than 170 degrees. If the viewing angle is specced at 160 degrees, its a TN.
If the monitor is very inexpensive, it is most likely a TN.
If you have a chance to view a monitor in-person, TN monitors turn so dark as to be un-viewable if you look up at them from below. They lighten very much when looked at from the top.
The 2051's were good, but we may have seen the last of them, unfortunately. I'd still avoid TN's if I were me, but if I absolutely wanted to spend only $200, there are some 22" panels that can be had for around that price.
