Accidently Shorted Motherboard
efran1526
Hi:
Last week I forgot my computer was on and I attempted to connect power to my hard drive. It sparked and system shut off. When I tried to restart it the fan on the motherboard started and then immediately shut down. I took the battery out for about an hour and replaced it then the system started fine and booted up. However, the hard drive runs very slow now almost there is not enough memory. Thinking I may have damaged the hard drive, I put in a new hard drive and the result is still the same. Does anyone know what may be going on? Here are the specs:
Motherboard - Microstar 6309
Memory - 1 gb (registers in system)
Pentium III 800Mz
40 gb hard drive
Thanks for any help.
Eric
It's very rare that a short/voltage spike would cause a problem like this. Usually it fries the component altogether or does nothing at all...
Maybe when you took the battery out, the BIOS defaulted to a safe mode where the Ultra DMA is turned off for the IDE controller... try checking your BIOS setup options.
IDE drives tend to be more sensitive to possible failures especially electrical ones, especially due to that they are not like sata drivers in being designed for hot swapping (under certain configurations). I would advise you download a HD testing app like the one linked below to test the HD and see if it can complete or use the active smart application to check for possible smart information indicating an HD failure. I would also agree with Xeth ensure you have put your bios back into an optimized mode for correct performance. Also make sure to cover the basics and use a different ide cable and different power molex connection.
http://www.hitachigst.com/hdd/support/download.htm#DFT
Hard drive diagnostic
http://www.ariolic.com/activesmart/index.html
Allows you check overall smart values and overall health of your HD
Thanks for the replies. I will check both responses and see what happens. Will let you know how it goes.
Thanks again.
Eric
Thank you guys. I applied the settings and it seems to be running much faster now.
Very much appreciated.
Eric
