Montinovich
- Oct 4, 2010
Hi all, first time poster
Yesterday I somehow managed to press the CLR CMOS button on my motherboard, but at the time I did not know what it did. I'm running RAID 1 on two 1tb Samsung Spinpoint F3 on an ASRock x58 Extreme6 mobo and the pc would not boot properly, but i somehow managed to get into windows which ran somewhat laggy, so i shut down the system and found out that I was supposed to go into BIOS and change the HDD setup to RAID before going into windows after a BIOS reset, which was then too late.
I tried to put in the Windows 7 disc (64bit) and tried to run the repair options, but none worked as they all stated they needed some files or something of the like (which I assume is messed up due to that I went into windows after the CMOS clear). I don't mind doing an OS reinstall, as long as i can just preserve the data on my HDD's somehow. I tried plugging the F3's into an old Dell dimension E520 with Vista, which recognized the drive in BIOS but didn't show in "My computer". I also tried hooking up the E520's HDD to the pc with the RAID HDD's but just after the green vista loading bars a quick blue screen appears (just a quick flash) and the system reboots. Right now I can't even load the windows 7 disc, as it says: "Windows failed to start. A recent hardware or software change might be the cause" when i boot from the disc drive and the HDD's.
So i just want to access the data on my F3's so i can backup what is on them, but I can't even get them to show when plugging in to the E520. Also, I want to get windows 7 up and running again (don't mind reinstalling and recreating the raid if i just have the data backed up). Could I just remove one of the hard drives and then delete the RAID volume in the RAID utility, do a clean OS install and then configure raid again or something? Sorry for the long post and confusing explanations but I don't really know where to go from here. Thanks in advance, I appreciate your help!
