i just bought a new hole saw a while ago for 80mm fans (3") hole saw... i am about to drill a blowhole for the first time in metal... other times were done in plastic which was fairly easy even without a hole saw... cutting the hole isnt going to be difficult with a hole saw since i will get a round hole.... but cutting the holes for the fan screws, will be kinda hard... when i did blowholes in plastic, and i mis-align the fan screw holes, i usually grind it a lil bit so its bigger but the screw can reach the hole... but right now im doing it in metal and once i cut the fan screw holes, i cannot make it any bigger
now, im just trying to find out if theres like a printable template for a blowhole so i can tape it on and drill with it as a guide... ive looked thru the FAQs but i havnt found one so im checking with you guys first just in case this really exists
thanks
thanks
