Accelero Xtreme IV 280(X) mounting question
scoop
Hi,
Would someone please give me some guidance on mounting the Accelero IV 280(x) on my Visiontek HD 7950?
The instructions indicate that I should apply the included thermal pads to the backside of the card where hot components are located on the opposite side. I’ve marked the components that I think this step applies to, but I’m not sure I’ve included everything. Would someone please mark my pic where the “hot” components are located so I can apply the thermal tape properly?
Thanks very much for your help.
You missed the card power VRM, its the strip of mosfets between the 2 rows of caps on the right side of the card.
