Accelero Xtreme 7970
Vesqwi
Does it fit any 7970 reference brand or is it restricted to some brand only ?
(I guess I will have to remove the stock fan to instal this ? (sorry I'm total newbe)
Thanks
It will fit on any reference PCB and obviously you will have to remove the stock cooler but if you don't have experience installing aftermarket coolers you shouldn't do it imho, the installation process its not exactly easy.
Thanks,
Actually the plan is to get the job done by someone else.
