Ok if you look at the twin turbo pro page it says max cooling 120 watts.
now on the s1 rev 2 page it doesnt show max cooling. I think they are baiscly the same cooler with 4 pipes .
Just a refresh with better vrm sinks.. why buy the new cooler when you can buy the old and add your own 92mm fans with zip ties and add your own vrm sinks ??
I want to see a review comparing these 2 coolers side by side on a 5870 since they both fit.
Accelero S1 Rev.2
Verses
Accelero TWIN TURBO Pro
Accelero S1 Rev.2
Verses
