Accelero S1 goodness
Hagrid
I bought this for my 7900gs too see about some overclocking until I get a 8800gt or even a 3870. I though this thing was big, but dam, its HUGE! I also put some epoxy on the little heatsinks for the memory(arctic silver epoxy). I also have a 120mm fan blowing across the HS at a 45 degree angle so it blows towards the rear. Temp idle is 42.
The games coming out seem hungry for power and going to SLI/crossfire seems like a good solution. Will the accelero fit in a sli configuration? Wondering if anybody has em on both cards.(8800gt's)
Thanks!
Why take them off? They will be staying with the card. They are cheap to buy($10). :)
Well, if you want to buy more that's cool.. though it will make RMA'ing the card difficult if you ever need to.
