AC'97 Vs. HD Audio?'s
Format _C:
I am assembling a computer out of old and new parts (The case being one of the older parts that only has an AC'97 Front Panel Connector) I am using a Gigabyte GA-MA770T-UD3 as the motherboard and it supports only HD Audio
So my questions are.
1. Is there any significant differences between HDA and AC'97 (Other then the wiring?)
2. Can I rewire the front panel cable to an HDA connector or do I need to replace the jacks themselves?
I am only going to use the jacks for a Pair of headphones and a Mic (Both occasionally so the jacks would be empty most of the time
Thanks
Youi know I have always wondered but never knew either. Hopefully this thread gains a little momentum.
I believe the actual difference depends on the implementation. But HDA is newer and technically (theoretically) better, including allowing more channels.
