after reading numerous posts regarding pc optical out to receivers for 5.1~7.1 surrounds...I'm completely confused.
Current budget HTPC setup:
Shuttle SK43G
Duron 1.2G (yeh i know....)
1gig ram.
AC97 with optical out.
It's connected to a HDTV via VGA.
Its main purpose is video playback: DVD/Divx/AC3/web downloads of various formats.
So needing to output 5.1 is rather important.
Currently hooked up to a Onkyo 7.1 receiver that supports both optical and 5.1 analog input. There are only 2 fronts and a subwoofer connected to the receiver though, more to come laaaater.
I understand using analog 5.1 input will work for sure. But I really prefer not to do that if the same can be accomplished using optical when properly setup.
When I hooked up the optical with AC97, set it to optical output and all. The speaker test only made it to the 2 speakers and not the subwoofer. Is that normal? I would think even for stereo mode something should come out of the sub too....
I used media player classic to playback The Matrix just to see if I'm getting anything from the subwoofer, still....nothing
I set mpc to use S/PDIF outpout.
Is this simply the nature of AC97 when using optical out?
Can this problem be solved by using Chaintech AV-710(or the like) optical out? if so, what's the difference with AC97?
someone please point me to the right direction with simple solution to this, besides using analog 5.1 please
Oh I don't care about the gaming possibilities since this is strictly HT.
What proper players and codecs should I install to play back virtually all the videos formats. While achiving surround sound output via s/pdif?
Please guide me through this
and thank you for reading through yet another optical out question....
Shuttle SK43G
1gig ram.
