AC97 No Sound after RAM Install
JRW160
I just installed another stick of RAM in my computer and reset the CMOS. When I got back into windows, I have no sound. I checked in the bios to see make sure the AC97 was enabled, and it is. I then unistalled the drivers, restarted, installed new drivers, and restarted again. I still have no sound. I am at a loss as to what to try next.
When you say no sound, do you mean the sound just doesn't come out of the speakers, or you get an error when you try to play?
Ie, if you start winamp, will it LOOK like it's playing?
If so... this may sound obvious, but make sure you've got the audio plugged into the right place, that your speakers are turned on + up, that your audio is not muted... you get the idea.
Have you tried removing the memory to see if you can confirm that it's causing the problem?
Erik
It does look like it is playing. Just no sound come out. I checked to make sure my speakers are turned up and nothing is muted.
I haven't tried to remove the memory, but I haven't had sound since I restarted after installing hte new RAM.
Is the soundcard detected at all in the hardware manager?
It's onboard sound, and it shows up in device manager like it is working.
I am pretty sure this motherboard is mesed up. I had a lot of problems with the dimm slots. I uninstalled the new ram to see if it was the problem, and I still ahd no sound. When I tried to reinstall the new ram, I kept getting no post and a single beep indicating memory error. I tried the two sticks of RAM in every possible configuration of slots. Sometimes it would give memory errors, and sometimes it would post. When it did post though, it only recognized half of the ram. I ordered an nf7-s, and I am just gonna RMA the old AT7 to abit and use it in another box or something.
