After seeing how fun the Source based games are running on my computer, a buddy of mine decided to pick these games up.
His Comp: Dell Inspiron 9100
P4 Prescott 3.2 ghz
512mb ram
Mobility 9700 64mb
I figured his computer should run it somewhat decently since it's ATI based.
So I get on his computer, eliminate a bunch of his bloatware boot services (thanks Dell), cleaned out 3 viruses, 4 trojans, and loads of spyware. Now that it runs Wndows decently we install the game.
The game runs like crap at every possible settings combo I can come up with. Sub 20 fps in all cases.
The best I managed to get in CSS Stress Test at 1024x768 (medium settings) was 36 fps, which is kinda playable since he isn't picky. But the problem is that if you try to run the test again at the same settings the FPS will drop in every subsequent test. So it isn't keeping any sort of consistant performance.
I tried the lastest mobility drivers from ATI's site (Proper Uninstallation with Driver cleaner). No luck.
I tried the lastest Omega's with the same uninstallation process. Performance went up a bit, but no real luck.
I tried lowering quality settings in the driver. I tried turning off Catalst AI.
Another strange issue is that when I go into the device manager, it shows that he has 5 or so monitors being used.......after uninstalling each one, or disabling them, they come back after each new boot. Even after they are gone on the current boot, the problem isn't fixed.
I'm running out of options here and his $50 spent on games is looking like a waste.
My other friend's computer with a P4 3.0 and a Geforce 2 is running the game faster.....
Is there something I don't know about these mobility cards? The Mobile 9700 in my Apple Laptop runs games on all high, so I'm kinda lost.
I'm contemplating a reformat on it, but I'd rather not have to.
Any help would be appreciated.
P4 Prescott 3.2 ghz
512mb ram
Mobility 9700 64mb
