Absolute Minimal mATX Low Profile Case
BecauseScience
I'm in search of a tiny mATX case that supports:
  1. all four low profile cards allowed by the mATX spec
  2. one 2.5" drive
But not:
  1. conventional power supply
  2. 3.5" drives
  3. 5.25" drives
  4. full size cards
It should be around 10 x 10 inches and 3-5 inches high. Power will come from a picoPSU style dc-dc converter so there's no need to waste space on a conventional mATX / flexATX psu. Ideally, the space provided for the 2.5" drive will fully overlap the motherboard.
The result should be very similar to the M350 ITX case but large enough for an mATX board and with a low profile four slot card cage.
The Cooler Master Elite 100 seems to come the closest. Too bad they decided to put a conventional psu in there. The Elite 100 would be exactly what I'm looking for if the psu was gone and a low profile card cage was put in it's place. It could be a couple inches shorter front to back but I could live with it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119211
http://www.xbitlabs.com/articles/cases/display/mini-itx-cases-roundup_4.html
Low profile desktop cases like the IN WIN BL series have a low profile card cage but they add 3-4 unnecessary inches to accommodate a psu and drives.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108065
The IN WIN BK series is close. I could live with the extra width lost to full height cards if the bottom area that holds the psu and drive cage was gone.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108191
Has anyone ever see anything like what I've described?
Yea if you google DM-387 you'll see that there are quite a few different "manufacturers" selling that same case. It's nice and thin but it's far too long (back to front) for me. Newegg lists it as 15.8 plus bezel and that's at least another inch judging from pictures.
I absolutely need under 11 inches back to front including bezel. The IN WIN BK's are the closest I've seen.
Apparently, some of the larger mini-ITX cases also support mini-DTX. http://en.wikipedia.org/wiki/Mini-DTX
Some of the smallest mATX boards are also mini-DTX compliant even though it's not mentioned in the specs. Example:
Foxconn G41S-K LGA 775 Intel G41 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186178
If your board is a little over the mini-DTX spec it looks like you can often squeeze it in by ditching a drive cage or tossing the psu and replacing with a picoPSU. You may lose a slot in the process.
There are a decent number of mini-DTX compatible caes that come in near my size requirement.
