- Aug 16, 2004
Hello there, just wanted to toss up my work in progress log. I decided to dip into water-cooling since I got a great deal on a kit, but sadly my Lian-li A05b just wasn't up for the job without some major modding to get the airflow I wanted.
Sooo I am transferring some stuff over to my new ABS Black Pearl that I got for $104 shipped after taxes and what not.
Anyways, on to the pics, and I will apologize for the crappy pictures and horrible lighting in my room.
First thing first, I was sooo excited that she got delivered that I stripped her down right away
Here's my old rig, temps were horrible with the radiator mounted on top, so I took it out and dropped temps around 13c. ( 71 load now with my overclocked i7 920 ).
Num Num Num
Some new parts, yate-loon high-speeds, Swiftech MCR320, XSPC reservoir, 20ft maskateer 7/16" tubing, and a Lian-li EX34N cage ( yeah yeah this is a Lian-li V2000 at heart! )
I don't like the looks of this case with the side panel cut out so you can mount the radiator sideways. And I doubt I have the jigsaw skills to make a perfect factory looking cut
, so I am mounting the radiator on the mid-panel where imperfection is more forgiving.
Here are the cuts I've made with a radgrillz mounted on it. Threw some Petra's C-strips on there just to see how it looks like before I paint.
Cut in the back for cable management, easily sliced through it with a jigsaw.
Filling in the mounting holes I won't be using, not quite flat enough yet so I am leaving a second layer overnight and sanding in the morning, using 320grit sandpaper.
Working with aluminum scratches soooooo easily, so I am going to be priming the inside tomorrow and hopefully getting everything flat black if I have the time.
Any feedback/suggestions/tips are appreciated as this is a work in progress.
Num Num Num
