ABS Majesty 1100W PSU
vjcsmoke
Can we have a review of the ABS 1100W power supply please? It's one of the few 1kw+ power supplies I can find that is gold certified.
17-814-019-Z07
http://www.newegg.com/Product/Product.aspx?Item=N82E16817814019
Also should this PSU be able to handle 2x5970 OC + i7 920 OC + PPU video card?
Is it better or equal to the Revolution 1050+ or the BFG EX-1200W?
Heatsinks look like ATNG to me. UL number traces back to ABS, so the specific OEM is unknown for certain. Since it managed to get a gold rating it's probably decent, but I doubt it's at the level of the Revolution85+. The EX-1200 isn't a particularly amazing PSU at higher loads, so it's possible it can equal that. And 1100W is plenty for two 5970s and a PhysX card.
