About to pull the trigger.. hows this build sound?
blisk
Q6600 (debating Q9550)
Asus P5Q Pro
G.SKILL 4GB DDR2 1000
ATI 4850 (depends.. will see as soon as there are benchmarks for 1gig vs 512 for the 4870)
Not sure on the heatsink yet... haven't looked into that... if you know a good one that'd help a ton.
Anyone see any issues with this setup? I plan on overclocking and want the most performance I can get for the money I have set aside... the Q9550's price difference isn't a huge issue for me but since its not E0 stepping (decided its too long to wait with the nehalm just around the corner) I'm assuming I can only get on average around 3.2 compared to 3.6 with the q6600... which makes the q6600 the much better deal and the one I'll have better performance from. Does this sound about right?
What's your budget?
What resolution do you game at?
Do you have a power supply and hard drive?
As for a heatsink, I'd suggest the Xigmatek S1283 + bolt through kit, near TRUE performance for half the price.
What is the primary use of this build? Gaming? Video encoding? General usage? All the above?
The Q6600 is solid Quad core cpu. Though it's been around for quite some time, it still rocks and is definitely no slouch by any means. If you O/C this to over 3ghz I don't see this as an issue when you game. I don't feel the $300+ cost of the Q9550 is worth it especially when the LGA socket 775 will eventually become obsolete. I would get a Q6600 for under $200, O/C that cpu and just enjoy that for now.
What's your budget?
Well don't want to spend more than $800 including GPU... less is always better... however:
Thats a good point and I'll just save the money for a better video card where it matters.
I currently have a 7800 or 7900 and will probably keep it until I see how how performance at 1900x1200 is affected by double the memory on the 4870 before deciding on 4850 or 4870. Also want to keep it for a good year or two before upgrading again. How does that sound? Think a 1 gig 4870 is worth the wait? I game at 1900x1200.
Antec Earthwatts 500watt PSU... I just bought a nice 1 terabyte Hitachi drive cause my current one is making clicking noises.
The power is needed mostly for gaming. The other thing I do is investing.. and also thinking about adding another monitor for that down the road. I'm starting to get into backtesting and all that... basically running algorithms looking for patterns stocks... so quad would be nice for that (even if it might not be necessarily multi core... not sure) as I can then browse the web (which I spend most of my time on my computer doing with lots of tabs open) and do something else while that's running in the background.
If you are already gaming on a 24" lcd with a 7800GT or 7900GT video card, you will really see a HUGE perfromance gain stepping up to a HD4850. It really depends on how anal you are on detail and image quality settings. Some guys wanna jack up the AA and AF and run most games at its native 1920 x 1200 res. Doing this drops the FPS in gaming and it slows down giving you lower FPS in gaming. If your $800 budget consists of only the CPU, MOBO, RAM and GRAPHICS you can get an HD4870 and still make your budget. The Antec Earthwatts 500 will be enough for your GPU and CPU.
Thanks for the info hardware guru. I think I'm going to wait a week or two and wait for the availability or benchmarks of the PCS+ HD4870 1gig that powercolor put out... see this pr release... and see how that affects the higher resolution like 1920x1200 if at all. If not I'll just go with the standard 4870.. maybe one with a good heatsink/fan so it doesn't have alot of noise/heat like I've heard the 70's have.
Went with the Xigmatek htd-S1283 ... buying it right now.
Yep picked up the bracket too... appreciate the help guru, and everyone else.
