This will be a desktop system, meaning it will indeed sit on top of the desk I will be working on, so it would be nice if it were as quiet as possible.
Please check my shopping cart for any glaring errors:
Antec Solution Series NSK2400 Black/Silver Computer Case - Retail comes with 380W PSU
BIOSTAR TForce6100-939 Micro ATX AMD Motherboard - Retail
G.SKILL Value Series 2GB (2 x 1GB) 184-Pin DDR SDRAM Dual Channel Kit System Memory - Retail
AMD Opteron 146 1000MHz HT Socket 939 Processor - Retail
ATI Radeon X1800XT 100-435705 Video Card - Retail
HITACHI Deskstar T7K250 250GB 3.5" SATA 3.0Gb/s Hard Drive - OEM
ZALMAN CNPS7700-CU 120mm 2 Ball Cooling Fan with Copper Heatsink - Retail
ZALMAN VF900 CU 2 Ball VGA Cooling Fan/Heatsink - Retail
Scythe S-FLEX SFF21E (1,200rpm) 120mm S-FDB (Fluid Dynamic Bearing by SONY Corporation) Case Cooling Fan - Retail - 2x to replace the original case fans
COOLER MASTER SAF-S84-E1 80 x 80 x 25mm SuperFlo Case Cooling Fan - Retail - to replace the original PSU fan
I realize that Nexus/Yate Loon fans are probably even less noisy than the Scythe ones, but Newegg doesn't carry Nexus and I just want to buy it all from the same place.
